electronic ground plane...... good?
Speedy007
CB Handle: Little Bilko
Sat Mar 08, 2008 7:42 pm
Hi all, on my current Iveco Stralis, ive put my arial on the corner of the sun visor outside where it bolts to the front of the cab. (Got an Orbitor) on the mount and is pretty good.
However, ill be getting the new stlye Stralis in a few weeks, and looking at them i cant do the same, as they have changed the sunvisor mounting. So im thinking of getting one of these EGP mounts and just sticking it on the plastic faring support on the bck of the cab...(the roof is fiberglass anyway).... as its easy and less hassle etc... Are they any good?
Also i have a CB already on the front as standard, which looks like you have to screw a screw into, i havnt used this as im confused what arial i can use?
Just wondering if you guys can help me out please?
Speedy
Sun Mar 09, 2008 8:16 am
epg is for use when all else fails will give a perfect swr but makes the system deaf
