how do you fit a cb anttena into a volvo fh cab.
Thu Mar 12, 2009 4:25 pm
hello everybody,
i would like to ask how do you fit a cb anttena onto a volvo fh cab as a friend of mine at work has a volvo fh i looked at the cab and thought of a gutter mount to fit onto the gutter at the back of the cab then i thought how much cable would he need and how would he put the cable into the cab to his cb radio as his radio will be on the dashboard so it will be easy to reach he has a 5" orbitor whip,
i have to admit these new upto date trucks are very nice inside and outside but dont make it easy where to fit a cb antenna anymore,
kind regards,
Thu Mar 12, 2009 5:18 pm
migth be better putting one of these on see alot of truckers with them http://www.thunderpole.co.uk/cb_radio_f ... mounts.htm
Fri Mar 13, 2009 7:57 am
volvo have a cb antenna mount on the nearside roof with the cable conmeing out at the back of the switch panel over the drivers head needs a plug or extension fitting depending where nyou whant to fit the cb dead easy to do once you have done a few hunndred
Fri Mar 13, 2009 9:45 am
i had the same prob but sorted it now but in the car
Fri Mar 13, 2009 4:15 pm
good deal thank you for the help lads stampman we never knew that volvo already had a mount for a cb anttena on the roof i already have a spare adapter for a 3/8 anttnna for a dv27 base we are just short on pl259 plugs #-o i also forgot to mension and this is good news we dont have no globetrotter cabs only the aerodynamic air kits,
cheers and beers for the help lads take care to you both the help was very usefull to my work collegue.
Fri Mar 13, 2009 7:39 pm
alright mate
Sat Mar 14, 2009 9:40 am
no problem
Sat Mar 14, 2009 11:12 am
:D
