tipper truck drivers
Lorry CB radio advice and troubleshooting
slimfb
Sun Mar 10, 2013 2:41 pm
hi all
any of you guys out there with a recommended set up ?
big steel body on a 24 v merc
Sun Mar 10, 2013 9:49 pm
TTI TCB-900 is DIM Mount size 12 or 24v scan function and front speaker http://www.thunderpole.co.uk/mobile-cbs ... b-900.html
Team Roadcom-FS is din mount 12 or 24v front speaker and has scan and dual watch and VOX http://www.thunderpole.co.uk/mobile-cbs ... om-fs.html
Team Roadcom-FS http://www.youtube.com/watch?v=KLcOMZ2Ck_0
Mon Mar 11, 2013 8:43 am
USE the intek a lot better set wired to the 12volt supply in the wagon with an orbiter on a gutter mount at rear
works very well fitted quite a few this way
somersetboy
Sun Aug 18, 2013 8:28 pm
I've a Harry in the 54 FM12 twig is a big stinger mag mounted to the roof and swr'd in sensible and I've had no issues. Gets out better than anyone else in our yard.
AppleTree
CB Handle: Ben
Fri Jan 10, 2014 7:30 am
somersetboy wrote:I've a Harry in the 54 FM12 twig is a big stinger mag mounted to the roof and swr'd in sensible and I've had no issues. Gets out better than anyone else in our yard.
Most of our trucks have this set up, my blade has a similar set up too...
One Life, Live It!
Buzzin' Around Channel 11 Usually.
