Scania Topline - where to fit antenna
Diesel-truckin
Sun Nov 02, 2014 3:53 pm
Hi all,
I've recently acquired a cb with a large antenna on a mag mount. I drive a Topline 12 plate scania and wondered where is best to place the antenna?
The Topline for those who don't know, is 13'10" high... So on the roof, the antenna smacks everything I pass under!
Thanks,
Adam
Mon Nov 03, 2014 8:09 am
forget the mag mount unless it is the wilson 1000 fit guttermount on the rear and feed the coax through the grommet on the back to the cb
Diesel-truckin
Mon Nov 03, 2014 7:04 pm
Thanks for that, any particular gutter mount? I assume the thunderpole standard gutter mount would suffice?
Thanks,
Adam
Tue Nov 04, 2014 8:56 am
ask colin for the sirio one when you order and dont use a snail mount on it as they let water in for fun dv mount is the one you need
Diesel-truckin
Tue Nov 04, 2014 8:21 pm
Great stuff. I'll be making the call tomorrow afternoon no doubt, thanks for your advice.
Thanks,
Adam
Wed Nov 05, 2014 8:28 am
no problem have fitted quite a few r series and you may have to run 12 volts up to the top as well as scani are cutting back at one time the used to put 12 volts up there but theses days its a bit of a lottery
Diesel-truckin
Wed Nov 12, 2014 9:35 pm
stampman wrote:no problem have fitted quite a few r series and you may have to run 12 volts up to the top as well as scani are cutting back at one time the used to put 12 volts up there but theses days its a bit of a lottery
Might be moving companies after this weekend! Hoping to land a scania again as I've settled into them now!
If not, I want a Volvo with the I shift...lovely motors.
Thanks,
Adam
