renault truck build in cb system
ollie1001
Thu Feb 05, 2015 7:15 pm
Hi. I have just took over a renault premium. It has a built in ariel and I presume a power point for my cb. Can anyone shed any light on where about the ariel jack and power point is. Thanks
Sun Feb 08, 2015 8:39 pm
The 12v takeoff and coax connection will most likely be in the spare radio slot , http://www.fierdetreroutier.com/zoom/es ... Bgr%5D.JPG
marusches
Sat Mar 07, 2015 11:16 am
if it is anything like the mercedes own cb stuff you may want to bypass and use your own gear as they are pretty poor
Mon Mar 09, 2015 8:52 am
some Renaults cb connection look as though they are for a telephone and the power needs a meter to find it as they like using 1 color of wire throughout the system
Wed Dec 16, 2015 9:09 am
just done a renuault 510 and the cb antenna was swr perfect on 25 megs and totaly useless between 26.965 and 27.99125 had to have a conversion made to fit an antenna which will do the job
Wed Dec 16, 2015 6:03 pm
In my DAF the 12v takeoff is next to the Digie Tachograph ( see Picy ) , needs a female match for the CB wire .
DAF 12v plug(800x450).jpg (37.25 KiB) Viewed 2285 times
