Wanting a CB
Mini CB radio advice and troubleshooting
5cotty
Tue Jan 30, 2007 11:06 pm
Just done up my mini and now wanting a CB, had alook around and there seems to be alot out there. I just want 1 that I can wire straight into the car via 12V and has a built in speaker.
Any help or links would be great.
Scott.
Wed Jan 31, 2007 9:47 am
just look at the home page on this site and you will be spoiled for choice always remember its the antenna that makes a set up work well
5cotty
Wed Jan 31, 2007 5:44 pm
Yeh I've had a good look but I'm still lost, non of them say built in speak. What model covers everything? I ant bothered about cost really I just want something with everything! built into 1 unit which I can wire into 12V and then just attach an antenna and it will work.
Any help would be great.
Scotty.
Wed Jan 31, 2007 8:41 pm
most cb's on this site are multi banded if your not sure what you whant give colin a ring and he will sort you out for the cost of a phone call
:D :D :D :D :D
Basilsparents
Thu Feb 01, 2007 7:17 am
5cotty wrote:Yeh I've had a good look but I'm still lost, non of them say built in speak. What model covers everything? I ant bothered about cost really I just want something with everything! built into 1 unit which I can wire into 12V and then just attach an antenna and it will work.
Scotty.
ALL CB radios made nowadays have a built in speaker.
Thu May 16, 2013 9:51 pm
thought they always had a built in speaker all mine did ever since the mid 80s cough cough bigger the antenna the better well anything over 5 ft you wont go wrong, :wink:
Sun Dec 01, 2013 7:28 am
Every cb radio has a built in speaker
andyson36
Sat May 13, 2017 3:12 am
I thought about just getting a longer version of the standard twig. I presume that's what that is? Would it work better if it was a bit higher than the cab
gclub
