dont mean to be dumb..lol
stoner_26
Sun Apr 24, 2011 3:43 pm
hi all, i dont mean to be dumb or ask a silly question but i dont underdstand so thought i would ask... i have only had a cb for a few months and been using a mag mount in the roof, i want to use my cb now in my house and not having much luck with getting a low SWR on metal things in the home, lol so looking at getting a ourdoor antenna but not sure which to go for, looking not to bad and cheap :P and i dont understand how a outdoor antenna doesnt need a groundplane but a car antenna does :S any help would be great so i can learn more and understand how it all works, thanks.. james
Mon Apr 25, 2011 10:58 am
antron 99 stright 18ft diapole looks good and works well does not need ground plane put up and use
stoner_26
Tue Apr 26, 2011 7:28 pm
ok thanks, with any antenna outside do i need to use a steel pole or isit just advised to give better signal? if i just bolted an antenna to the side of the house and ran the coax cable to the ground incase of lightening would that work ok? thanks :P
Wed Apr 27, 2011 9:04 am
stand off t&k brackets with a 2 meter pole will work fine only ever heard or new of 1 lightning strike and his handle was saint john so he was tempting fate anyway
stoner_26
Wed Apr 27, 2011 9:12 am
i just checked map*ins and they have t&k brackets for 20quid, so can i just bold the antenna straight to the bracket? and u think not to worry about the coax for lightening? thanks
Wed Apr 27, 2011 9:30 am
20 quid seems expensive.
We have all the fittings here... http://www.thunderpole.co.uk/base_stati ... sories.htm
stoner_26
Wed Apr 27, 2011 9:36 am
thanks, jst had a look at the link and thats better prices :P lolso could i just both the t&k brackets to the side of the house and fix the antenna to the bracket or do i need to use a pole from the bracket and then fix the antenna to the pole thanks?
Wed Apr 27, 2011 9:53 am
You need to use a pole. The pole clamps to the T&K's using U bolts, then the antenna clamps to the pole.
stoner_26
Wed Apr 27, 2011 10:15 am
do i need to use a pole for the groundplane? and it there a minimum length the pole has to be? thanks
Wed Apr 27, 2011 11:01 am
no the pole is simply to mount a round antenna to a flat surface on the the brackets and gets the antenna a bit higher
stoner_26
Wed Apr 27, 2011 11:16 am
ohh ok thanks, sorry for all the questions but its just so i understand :) so what clamps or brackets do i need to fix my antenna to the pole? thanks james
Wed Apr 27, 2011 11:24 am
All the homebase antennas we sell come with brackets to attach them to a pole.
Wed Apr 27, 2011 3:17 pm
the only thing extra you will need is coax so if you order it from our sponsers they will sort you out with the full kit all you will have to do is drill and screw
