Antenna cable run issue
matchbox
Thu Jul 28, 2016 11:49 am
Good morning all.
I have a cable run issue. There is a telephone cable running down the gable end of my detached house from the facia board to about 2 feet from the ground where it enters the house. I need to run the antenna coax passed this telephone cable. This is the only gable end available to install my antenna as the other gable end of the house has no access at all for putting the ladder up. How can I cross or pass/bridge the telephone cable with the RG-213 coax without causing interference or bleeding issues?
Thanks in advance for any advice/help with this issue.
Fri Jul 29, 2016 10:46 am
no you should be ok just feeding it over the top
matchbox
Tue Aug 02, 2016 12:06 pm
Thank's stampman for your reply
If it ain't fixed, don't break it.
