Found Cb Antenna Help for home
ASPWLF
Wed Sep 06, 2017 5:38 pm
Ok so I found this cb aerial and it missing the top half but I want to ask i use this at home I have made a plug for it but will this antenna actully pickup anything at all ???
Also the other picture where I have the tv aerial thingy whatever there called would that work because it's fallen onto the roof and it's not up high so will any of these work ??
i can connect THE tv atrial to the top of my cb antenna with the copper pong thing
btw I have the arrival ontop of my window LOL it will help a small bIT but ain't picked anything up ;(
btw my friend also picked things up when he put it on his tv cable
i aint got £50 to spend on a ariela not even £20 what can I do to get signals from home ? What can I make a aerial out of
Thu Sep 07, 2017 10:44 am
any bell wire provided its the right length and set up as a diapole and it sholud get you started
ASPWLF
Thu Sep 07, 2017 10:17 pm
uhh it has broke beacuse i dont have the top half of the antenna :P see here i balance it on my window and u can see its missing the top half but i dont dont have a car also cant spend more than 10 on an antenna
Fri Sep 08, 2017 8:45 am
its missing the coil and the whip so will not transmit as its 2 short it should be about 8ft 6" long with the coil in place
Sat Oct 07, 2017 8:12 pm
try making a wire di pole antenna. the antenna you have is only fit for the bin :lol:
