midland power meter
tyrefitter
Sat Feb 28, 2015 2:44 pm
hi folks midland 48 multi plus when straight through aerial power meter on set reads between 1.5 and 2.5 if i run it through swr meter it says 3.5 to 4 anyone got any ideas swr is between 1.5 and 2.
cheers Trev.
Tue Mar 03, 2015 9:31 am
it will alter because you are adding a further resistance into the antenna line and it would seem the meter in the set may be set a bit low
tyrefitter
Fri Mar 13, 2015 7:26 am
Thanks for the reply stampman the set isn't 12 months old so may speak to thunderpole about it
Regards Trev.
markp
Wed Nov 25, 2015 9:29 pm
hey tyre fitter did you sort out the power meter issue ...this is uncanny ive just bought the same radio today and its showing the same ..cheers mark
