UK or CEPT setting advice please
Snooky the sweep
Sun Dec 27, 2015 1:01 pm
Hi all
I'm a noob and this is probably an SFQ
I got a T-1000 starter CB set up from Thunderpole via Santa.
Factory set for CEPT and aeriel factory SWR'd
Imagine my horror when all I can pick up is static and what appears to be music ?!?!
I did try a couple of , very nervous, transmissions for a rig check - no response.
Should I re programme to the UK setting?
N 8)
Tue Jan 05, 2016 1:26 pm
yes set to the uk and you can change between the 2 bands by simply using the am/fm switch
Snooky the sweep
Tue Jan 05, 2016 9:05 pm
Thanks Stampman
