Fitting Cigar Plugs
Wed Mar 18, 2009 9:33 am
hi guys just bought 2 cigar plugs for useing my radios in the car are they easy to fit to the power lead .??
thanks very much :wink: :lol:
Wed Mar 18, 2009 11:35 am
dead easy just need a soldering iron and red to the center
:D :D :D *King* *King* *King* *King*
Wed Mar 18, 2009 11:46 am
thanks stampman i will let you know how i get on ...should be fun lol
mpcapri
Wed Mar 18, 2009 3:29 pm
Mine was done for me, but changed rigs so de-soldered and re-soldered (+ taped) to new rig
cig1
cig2
cig3
Mart
BEER IS FOR LIFE,NOT JUST FOR CHRISTMAS!
26-TM-1969 - Red Squirrel - Spinney Hill - mpcapri - more aliases than what's his name
Wed Mar 18, 2009 4:29 pm
hi mart thanks very much i will get the soldering iron out later and have a go thanks again :D
Thu Mar 19, 2009 8:40 am
bigest problem is not getting burnt fingers
:D :D :D :D *King* *King* *King* *King*
Thu Mar 19, 2009 9:10 pm
i did mine but the power wasnt to good coming out of cigar soket and then the wire snaped from the solder so just use hombase rig now lol
mr p!e
Wed Mar 25, 2009 6:59 pm
I was thinking about this today, car manus dont seem to fit aux power out put adapters... its a nightmere... give it ago you may have to up the fuse rateing to cope with the current draw. check your car hand book to what fuse its fitted.
Wed Mar 25, 2009 8:15 pm
fuse should be about 15 amp so will be fine for cb
mpcapri
Wed Mar 25, 2009 9:20 pm
porky.69 wrote:hi mart thanks very much i will get the soldering iron out later and have a go thanks again :D
Sorry completely missed this Mr Paul, you're welcome btw.
Hope your soldering iron is better than mine, 20 years old and had the tip filed down a couple of times (wonder how many other people have also filed down their tips lol) will get a new one soon, do have a new gas soldering iron but keeping that for emergency use only.
Mart
Sat Mar 28, 2009 5:31 pm
lol
Tue Mar 31, 2009 7:22 pm
hello and thanks for makeing this thread a sticky ...just done my plugs very happy with them BIG thanks to all :D
Sat Mar 05, 2011 8:25 am
These 2 plugs have screw connections inside so no soldering needed .
Collection of Plugs in me garage draw for the use of .
HGV Truck type plug .screw type
Wed May 15, 2013 9:56 am
the 2 with the screws is a good idea dragonfly i`m impressed soldering is just time consuming :lol:
Thu May 16, 2013 9:02 am
the one with the screws is a lot better connection than the cig lighter type and is generally known as a heller plug
