Mount
Tega
Mon Nov 14, 2016 11:37 am
Hi there all
I just need a bit of information/help
I have a 2004 Mercedes Sprinter LWB.
I want to permanently Mount My aerial on the roof. I know I need to  drill a hole which is fine.
But my question is do I need to remove some of the paint work around the hole  to get a good ground connection. Also is it worth running a cable to a good grounding point on the body work as well.
Thanks for you time and help.
Mike
Tue Nov 15, 2016 8:21 am
no need to scrape the paint off or run an earth lead use a decent mount and you should be fine
