Fitting a PL259 Plug
logiesean
CB Handle: heymun
Tue Dec 03, 2013 8:58 pm
andy@thunderpole.co.uk wrote:Instructions on fitting a PL259;
1) Strip back the coax and pull back braid over cable
2) Put outer part of plug onto cable then screw inner part over braid
3) Solder end of the pin and trim excess wire
4) It should look like this!
Jeez ....seeing this brings back some very fond memories (yeh yeh ....i need to get out more :mrgreen: )
mcfeat
Wed May 07, 2014 10:42 pm
Just bought the compression plugs, never done this before. I've soldered the end of the plug but when I put my multi meter on it to test it I'm getting a reading on both the outer and inner pin and a reading on the outer and inner at the same time which I don't think is right if that makes sense. Anyone any pictures of the process step by step please
Fri May 09, 2014 8:34 pm
mcfeat wrote:Just bought the compression plugs, never done this before. I've soldered the end of the plug but when I put my multi meter on it to test it I'm getting a reading on both the outer and inner pin and a reading on the outer and inner at the same time which I don't think is right if that makes sense. Anyone any pictures of the process step by step please
try youtube mate *King*
