High swr and only 1 tx light.
Ferryman
Thu Mar 22, 2018 6:00 pm
Hi guys.
I have a stabo 3003 in my Scania truck and I fitted a stud mount through the roof and installed a thunder pole orbiter. I cannot get a low swr and for some reason when I key the Mike I only have 1 tx light instead of 4.
I have tried changing the stud mount and coax and even the CB itself but still have the same problem. Looking for some advise please.
Fri Mar 23, 2018 8:38 am
YOU NEED AN SWR METER AND IT SOUNDS LIKE THE ANTENNA NEEDS SHORTENING BUT YOU CAN ONLY TELL THIS WITH A METER
Ferryman
Fri Mar 23, 2018 6:24 pm
Ok I have a meter but it doesn't seem very stable. I'm getting a reading of around 3 which I know isn't very good. I can trim the whip if needed. Do you suggest 1/4 inch at a time?
Mon Mar 26, 2018 10:54 am
if its higher on ch 40 than ch1 it needs shortening and the are plenty post's about swr'ing on the forum
