puxing 777
- CB Handle: randombod
does anyone knwo if this radio can have the 446 freq added to it, if so how on earth do i do it i dont have the pc software to do it that way found what i believe is the 446 freq on thunderpole main site but i am struggling to program the radio (maybe it just cant be done
- Official CB Nut
IT CAN BECAUSE I RUN ONE ON 446.TURN THE RADIO OFF PRESS AND HOLD THE MONI KEY ON THE SIDE ALONG WITH THE MENU KEY TURN THE RADIO ON AND IT WILL DISPLAY SELF, THIS MEANS YOU CAN NOW TYPE IN THE FREQ. YOU REQUIRErandombod wrote:does anyone knwo if this radio can have the 446 freq added to it, if so how on earth do i do it i dont have the pc software to do it that way found what i believe is the 446 freq on thunderpole main site but i am struggling to program the radio (maybe it just cant be done
- Official CB Nut
you need to set the freq. step to 6.25 steps
- Official CB Nut
no it shouldnt. press menu turn the knob till it reads channel stepping ( step ) and press enter then select 6.25 press enter and then vfo/mr twice to exit
- Official CB Nut
sorry im down in dorset its a shame cause i run them with FANTASTIC results i also use the 888 again VERY good radiosrandombod wrote:You local to darlington north east ,i am very close to throwing the radio as i canna get the darn thing to program if u r fancy a guvy job programming it lol
i just dont know what i am doing wrong with this radio.. i think imanaged to step it but how will i know it shows 6.25 when i go in to the settings yet i still for some stupid reason cant add the channels and save them i must be thick -
Andy do you know about these little radios and are you at peterbrough landrover show again?
This is a call for help for someone who coudl possibly program the 446 range ch 1-8 on to this little radio as i am sure as hell pants at it does anyone in the north east know a shop / how to do it my good mate above has tried to give me the step by step (thank you ) but i am just being thick so any help is apprechiated
hi guys i am still struggling to prog the 446 freq to this little radio i have been unable to alter the freq and save them any one got a step by step guide in plain english please
cheers
cheers
- Bionic Budgie
- CB Handle: Bionic Budgie
Hi.
Puxing radios are very good, I have 1 VHF and 1 UHF and use them often. It might be that the radio doesn,t have 6khz steps. I programmed mine to the nearest freq and it works fine. Set the feq step to 5khz..The freqs are;
Channel 1..446.005
Channel 2..446.020
Channel 3..446.030
Channel 4..446.040
Channel 5..446.055
Channel 6..446.070
Channel 7..446.080
Channel 8..446.095
Hope This Helps.
Bionic Budgie
Diss 20
Channel 1..446.005
Channel 2..446.020
Channel 3..446.030
Channel 4..446.040
Channel 5..446.055
Channel 6..446.070
Channel 7..446.080
Channel 8..446.095
Hope This Helps.
Bionic Budgie
Diss 20
