Cobra MT-975 + Baofeng UV-5R problem
PMR446 Radio advice and troubleshooting
yoyoba
Sun Feb 17, 2013 10:25 am
I have been using Cobra MT-975 pmr-phones. Works great.
Now we have here some other walkie talkies, too. A couple of Baofeng UV-5R, these works great, too. But not together :(
If I select the channel 2 and CTCSS 1 then I assume it means 446,01875 MHz and the CTCSS is 67,0 Hz. Is that right?
I punch into UV-5R the following:
- 446,01875 MHz
- CTCSS 67,0 Hz
- low transmit power
- narrow
- offset 0,00000
- same with tx/rx ...
But I cannot get proper connection. I have some interference, bad noise, not working good.
Any clue? All ideas welcome!
Mon Feb 18, 2013 4:00 pm
sorry no idea about these set's set or operation
