CB speak!?!
Marmite
Thu May 17, 2012 11:30 am
Do people use CB speak?
If so, as a newbie to all this, what do I need to know????
Marmite Out.
Thu May 17, 2012 1:17 pm
not realy theses days
Marmite
Thu May 17, 2012 1:20 pm
That's ok then....I struggle with speaking the Queens English already :lol: :lol: :lol:
Thu May 17, 2012 4:14 pm
Thats a negative roger dogder!
Seriously not really anymore :D
bruce rae
Sat Nov 15, 2014 4:11 pm
i still do lol i think people should .roger breaker
Mon Nov 17, 2014 7:56 am
sounds like you will fit right in there marmite
Twocky61
CB Handle: Jay Walker
Fri Feb 17, 2017 1:06 pm
CB 18 Code
18-20 This is a sex appeal - Please donate generously
18-21 Not if I see you first
18-22 Do you eat shitty food or does your mouth usually smell that bad?
18-23 Go forth & multiply
18-24 If you remove her tongue from your ear maybe you will be able to hear me better
18-25 Baboons have a better sex life than you
18-26 Seems like a nice boy!
18-27 Are you about to go shankin?
18-28 About to go modulating with or without a mike
18-29 There’s more life in a corpse!
18-30 I had him/her!
18-31 Do you need some KY?
18-32 KY needed
18-33 No premax would be better
18-34 Do you like 69ers?
18-35 Person of the opposite sex required
18-36 Do you use rendalls?
18-37 No I burn rubber!
18-38 I need a cold shower
18-39 It depends who I shower with
Twocky61
Fri Feb 17, 2017 1:07 pm
CB Radio 13 Code
13-1 You’re an idiot
13-2 I’m ignoring you
13-3 You’re beautiful when you’re angry
13-4 Sorry
13-5 And you!
13-6 So what I made a mistake
13-7 If you can’t copy me it’s your fault as I’m running 2000 watts
13-20 Is the mike chinking or is it your loose uppers?
13-21 Are you being paid by the word?
13-22 Is that your voice or have you installed a foghorn?
13-23 If you had spoken for a few more seconds you would have qualified for a broadcast licence
13-24 When you are pissed you make more sense
13-25 The local CB’ers have had a whip round to buy your rig - so why don’t you stick to watching the Muppets?
13-26 Speak further from your mike if you can’t leave the onions alone
13-40 Your signal is great. Now switch off & give me a landline so that I can find out what you are on about
13-41 Either my rig is out of adjustment or you are on channel
13-42 If you are sober then my speaker must be up the chute - call back later
13-43 That was beautiful - now correct the mike & try again
13-44 Your rig has great sound - why did they discontinue making it?
13-45 Your transmitter must have a fault - there is smoke coming from my speaker
13-46 That’s what you call an antenna? I could get a better reception from 9 inches of wet string
13-47 What a marvellous signal - I will drive a little closer so that I can get a better copy
13-50 Slide down 250khz
13-51 You have tried upper & lower sideband - you have even tried both - now go QRT so that I can use the central slot
13-52 Good thing about SSB is that you are only half as offensive as you were on AM
13-53 Attention AM stations on centre slot - just because no-one will modulate with you on your channels what makes you think we will listen?
Twocky61
Fri Feb 17, 2017 1:08 pm
Ten code is as used by US law enforcement
