Coax Question
cheekychurros
Thu Apr 30, 2009 10:13 pm
What coax do you use for your Cb set up and scanner set up? I need a decent coax to run not only my Sirio 827 CB Antenna but also a scanner with a Sirio SD-1300U antenna also. I want to hopefully use the same coax?
Fri May 01, 2009 9:28 am
50 OHM is the one to use
Sat May 02, 2009 12:33 pm
50 OMH
Sat May 02, 2009 10:34 pm
lol #-o
FISH
Sun May 03, 2009 10:47 am
:roll: :roll: :roll:
26 TANGO MIKE 501
