Icom IC-R5
joe jeep
CB Handle: Joe-Jeep
Mon Jul 11, 2011 7:38 pm
I am hoping to win an Icom IC-R5, they seem good, their icom and they have a freq. range of 0.5 - 1300 mHz.
I want it to listen to civil and military aircraft and VHF ship and coastguard frequencies, so I think this should cover it.
Would, using an adapter, be able to plug it into a 9' cb aerial tank whip?????
Joseph
Handle:Joe-Jeep
Tue Jul 12, 2011 1:52 am
Tank whip is no good ,You need a dedicated multy band scanner Discone antenna . http://www.thunderpole.co.uk/homebasesc ... tennas.htm best mounted up high on your television antenna poll .
The V1300 covers 0 to 1300 mhz - http://www.thunderpole.co.uk/thunderpole-v1300.html
Thunderpoll Euro Stick is the cheapest - http://www.thunderpole.co.uk/euro_stick.htm
Tue Jul 12, 2011 8:27 am
yes you could plug into a tank whip but it depends how close you are to an airport for best results if you want better coverage then antenna as high as you can is far better but you will have to try it first on the whip
joe jeep
CB Handle: Joe-Jeep
Tue Jul 12, 2011 2:00 pm
I decided against the IC-R5 and I want to get it's predeccesor the IC-R2, It basically does the same job but a different button arangements and a few small gaps in inconspicous places of only 0.005mHz. So for a cheaper price for basically the same thing. I was thinking of getting the the Thunderpole Desktop, to stick on the garage door the same as my tank whip but at different times, oh and by the way my tank whip is performing pretty good for my location I got out 20 miles and was getting 9 on my signal meter when RX. The only question I have about the desktop is do the radials and discone aerials fold or detatch?? Might message Andy, He'll know.!
Joseph
Handle:Joe-Jeep
Wed Jul 13, 2011 7:42 am
if you order it you will definately get it they are experts in dispatch and packaging no problem order today get tomorrow
