mobile antenna for 2/70
g4tgg
Fri Sep 14, 2012 4:01 pm
New member, first post, hope I get it all right.
Have been looking for an inconspicuous mag mounted 2/70 mobile antenna. The Thunderpole micro dual band mag kit at 19.99 looks to be just the job. The mag mount is only one inch diameter and I feel a bit wary. My past experience with mag mounts is with ones with a six inch or more base. Any one using or used this antenna and if so how did you find it worked out. Would like some comments before I commit.
Many thanks and cheers.
73
Gordon g4tgg
Fri Sep 14, 2012 9:14 pm
I have not used one, Im not very familiar with there 70/2m antennas if you give them a call they will give you alot of advice
:D :D :D
Sat Sep 15, 2012 7:26 am
have a mate who uses this antenna and gets good results from it
