Where to put the antenna
Motorhome/Caravan CB Radio advice and troubleshooting
Gonewiththewind
CB Handle: Gone with the wind
Wed Mar 04, 2009 10:24 pm
I have an "Orbiter" antenna. Its goimg on the side of Motorhome high up. The issue is , front or back? :mrgreen:
On the road again.
Gone with the wind.
Thu Mar 05, 2009 8:09 am
dont use orbiter on side of motor home as the pick up a lot of reflection and will mnot come don on swr mount on roof if you can or as far out on the mirror arm to give your self a chance even use a center loaded or top loaded if you can only mount on the side of the vechial
killer cam
CB Handle: killer cam
Thu Mar 05, 2009 11:08 am
go for the front but you will probarly get tons of reflection but give it a try and if no good go for the mirror mount :D
Gonewiththewind
Thu Mar 05, 2009 11:25 am
Thanks for advice. Mirror is a problem as I see it as it is all plastic so will need additional earthing. initialy was going to mount on wing, but everything is double lined. Dont want to get into stripping before fitting.
More delays!!
Don
On the road again.
Gone with the wind.
killer cam
Thu Mar 05, 2009 12:16 pm
as i said wack it on the side if no good fiber glass the hole and you will have to find some where els
Thu Mar 05, 2009 1:14 pm
dont put on side use mirror mount ith earth lead easisist way and will not make a mess of side of van once yove drilled it you cant get it back to original if your near the sponseres let andy have a look
killer cam
Sun Mar 08, 2009 9:30 pm
how did it go then
Fri Jun 19, 2009 5:16 am
killer cam wrote:how did it go then
well i dont think it did lol *King*
MotorhomeMatt
CB Handle: Turtle
Sun Jul 12, 2009 11:45 pm
Hi Gonewiththewind,
Fitting an antenna is a bit of a nightmare to fit to a motorhome. I ended up getting a sheet of 16SWG steel, 2' x 4' , and welded a Sirio mount to the centre. I then gave it three coats of white hammerite over 2 weeks.
I bonded it to the roof of the motorhome (a 1999 Laika Ecovip 400i A class) with Sikaflex 221, and taped the edges with aluminium 'speed tape'. I earthed the steel groundplane to the motorhome chassis, and range is superb. I tried using a Firestik, then moved up to a Thunderpole superflexi, fitted on a spring.
Hope this helps. Just route the cables through a rooflight with enough loose cable so the vent can close down fully and make a seal.
It was a lot of effort, but worth it. There are pictures in the 'Gallery' Section, under "My set up, my pride and joy"
Incidently, in case you are wondering, I've had to change my name from 'Matt C' to 'MotorhomeMatt', because I changed my computer and a glitch wouldn't let me back in!!
Home is where you park it!!
killer cam
Mon Jul 13, 2009 6:31 am
lol i was going to say theres a man who had the same problem you should chack back in the forum some whear
Fri Jul 17, 2009 9:45 pm
*King*
Locoman
CB Handle: Locoman
Wed Jan 06, 2016 12:44 pm
Hi
I have similar problems with my Motorhome CB and SWR as I mounted the antenna on the Drivers side wing, but it is impossible to get a low SWR even with an Earth wire.
So now having a re think ??
Will have to put a grommit in the hole, sprayed White, Grrr !!
I am now thinking of clamping an alloy pole to the rear Bike Rack, with a mount attached at roof level, and with an artificial ground plain mount, then running the cable forward under the van to the Rig in the cab. And an Earth wire from the mount and attached to a suitable Earthing point
All this can be removed if needed, as I'm not going to drill any more holes in the van.
Any ideas or comments appreciated. :|
Locoman
The Problem is Not "Leaves on the Line", its the " Passengers"
Wed Jan 06, 2016 3:37 pm
you dont want the artificial ground as the seem to perform very poorly use a pole and add an 8ft 6" piece of ground wire to it do not earth to the vehicle chassis and try it out
Locoman
CB Handle: Locoman
Wed Jan 06, 2016 4:09 pm
I will try with out the groundplane and just add a good Earth wire as suggested, when its done I will post the results [-o<
Dickie831
Mon Apr 23, 2018 9:08 pm
Hi Locoman, just wondering if you got your aerial sorted and is so.. how?
Being new to CB radio, but wanting to get set-up on my moho I have spent a long time (and ended up buying too many unnecessary parts) trying to sort out the SWR on my motorhome set-up.. have a low-line moho, but like you, fibreglass /aluminium/ grp body and roof (and wifey insists no drill-holes anyway).. so had NGP mirror arm mount .. by advice.. along with mini orbiter 3ft aerial.. by advice... result is SWR well into red zone midpoint between 5-10 markings... have replaced NGP set up with bog standard body mount on a bracket with hard wired earth from bracket onto a solid fixing bolt in door.. SWR reduced a lot, but still on 4-5.. Spoke to someone with more knowledge and experience who advised me an orbiter is absolutely no good on mirror mount because it is a base-loaded aerial and is such a powerful aerial that it bounces RF back from the body.. had my set-up assessed and my ground is OK, but suggested thicker cable (may get a braided earth cable from popular internet auction site).. but also advised to get slightly longer and top-loaded aerial (which is now on its way to me in the post). I too have visions of me getting a pole fitted to bike rack !
