The Setup Grows...and my view
A place for pics, either of your setup, your vehicle, yourself or anything else!
Firetrap
CB Handle: FireTrap 26CT100
Fri Jun 19, 2009 2:58 pm
Just added a scanner to the set up with more bits on the way...
and up close...
Fri Jun 19, 2009 3:06 pm
have you done risk assessment for the tower you are building
:D :D *King* *King* *King*
Firetrap
Fri Jun 19, 2009 3:10 pm
double sided sticky tape :wink:
Max
Mon Nov 01, 2010 12:18 pm
Is the Nokia there a Mobile phone? or is it one of these fancy landline handsets, or a PTT Mobile?
FISH
Wed Nov 17, 2010 5:50 pm
nice pic lee
26 TANGO MIKE 501
Firetrap
Mon Nov 22, 2010 11:06 pm
Jeez! How embarrassing! To think i used to be proud of that set-up..
Oh well we all start somewhere, Here is where i am at now ;)
extremedave
Mon Nov 22, 2010 11:59 pm
is that a magnum in the middle and how do u rate it?
Firetrap
Tue Nov 23, 2010 12:14 pm
extremedave wrote:is that a magnum in the middle and how do u rate it?
It's same design on the outside as the Magnum 257.
This one is the MK1 Albrecht AE485s, Orange display rather than the new blue versions.
I have had a new version Albrecht AE485s and a new Version Magnum 257 too.
This orange display version does 25w variable SSB/FM and 6w on AM while the new blue ones do up to 30w on all modes.
It also uses more stable outputs than the new versions. While the new ones do work extremely well you have to be careful not to run them above 10w on FM as this will put strain on the ERF outputs casing them to fail and when they do they make a royal mess of the board inside and even if fixed they will never be the same again. The orange MK1 version does not have this issue so if you are getting one go for an older one and it will last years!
All in all a good radio, nice size, great RX and TX, loads of features, ideal for base or mobile use.
26-TM-037
Wed Nov 24, 2010 3:55 am
Stunning DNT :wink:
FISH
Sun Jan 23, 2011 11:35 pm
Like the ft840 lee
26 TANGO MIKE 501
