Thunderpole Orbitor: Aerial Help Please!
woodruffsdad
Sat May 15, 2010 9:40 am
I have a Land Rover Discovery which had a dodgy standard radio aerial. I replaced it with a Halfords rubber mast aerial which is not picking up good AM/FM radio.
So I bought a Thunderpole Orbitor CB radio antenna thinking it would screw straight into the Halfords aerial base and give me superb AM/FM reception but, of course, it doesn't!
Is there an adaptor available which will allow me to attach my Thunderpole Orbitor to my Halfords aerial base?
Sat May 15, 2010 11:10 am
no you will have to change the base but the results will be worth it
*King* *King* *King*
woodruffsdad
Sat May 15, 2010 4:03 pm
Is it easy to change the base without running a completely new aerial cable through the car? i.e. Could I attach a base to take the Thunderpole Orbitor to the existing cabling?
Sun May 16, 2010 8:59 am
you have to change the cable end to a dv plug as it needs soldering on it will be easier to change the whole cable
joe jeep
CB Handle: Joe-Jeep
Wed Apr 20, 2011 8:34 pm
Thunderpole stuff is fantastic quality and performs brilliantly!!!!!!
Handle:Joe-Jeep
