What to choose?
Eviltwin
Sun Mar 13, 2011 8:17 pm
I can't put an antenna on the roof, my home is less than 400m from the local Search and Rescue helicopters base, so during bad weather they can be taking off quite low. This means I can't stick an antenna up on the roof.
So, I've been doing some messing about with wire dipoles with little success thinking long and hard. At the bottom of my garden, about 10m from the house is the remains from a tree I cut down a couple of years ago. The stumps about 7' tall and fairly sturdy, so I'm figuring that If I used a short mast of say 3m tall, with a home base antenna, I'll get something that will allow an antenna with base height of about 15' up. As theres trees in the vicinity about 20m away, I shouldn't get any heli related problems. It still won't be fully above the roofline, but to the rear of my home is a fairly open field, which I think will offer a better location.
Now for what antenna to pick (the bit I'd like a spot of advice on)?
From the following, which would be most suited to the kind of location I'm intending on sticking the antenna?
Thunderpole 5
5/8 or 1/2 silver rod
Antron 99 (maybe adding the firestick top part later)
Also as I'll be essentially mounting to a tree, will the antenna need grounding?
Also as all of my CB experience surrounds mobile installations in the past, how do you ground an antenna thats made from fibre glass, like the Antron?
Mon Mar 14, 2011 8:40 am
the antron with the upgade shoul do you fine and it dosen't need extra ground plane
Mon Mar 14, 2011 9:34 am
The Thunderpole 5 can also be used with the 'Thunderpole A99 Upgrade'.... http://www.thunderpole.co.uk/a99-upgrade-stick.html
Plus we have had reports from more than one person saying that the Thunderpole 5 out performs the Antron 99.
Eviltwin
Mon Mar 14, 2011 3:59 pm
From what I've read, the Thunderpole 5 is better built too.
Does the A99 Upgrade Stick require much work to make it work with the Thunderpole 5? or is it just plug and play?
Also what about grounding/earthing the Thunderpole 5? Is it needed, or not?
26-TM-037
Tue Mar 15, 2011 5:45 am
Sirio Gain Master another option ...a few extra beer vouchers needed though :D
Eviltwin
Tue Mar 15, 2011 8:05 pm
Twice the price! Bit out of my range.
simon007
CB Handle: Simon007
Fri Mar 18, 2011 9:28 am
Check my youtube and see the fire up (search it)
I connected the fire up and needed no swr adjustment here. Here is the swr path on the mfj antenna analyser
Made with 4w FM
26000 2.0
26500 1.8
27000 1.7
27500 1.5
28000 1.6
28500 1.7
29000 1.8
And does although make the antenna overall length shorter but it seems to work really well.
Writer of Comms from Europe Radio User Magazine
checkpointcharlie
Mon Mar 21, 2011 10:12 pm
I replaced my antron with the TP5 and i have seen better signals and less noise it really is value for money antenna and beats higher priced aerials from other brands go for the TP5 im telling ya *King*
I want a hygain penertrator or mighty magnum what happened to the legends?
