mounting my antenna
gentle giant
Tue Mar 20, 2012 9:38 am
Could someone please tell me best way to mount the antenna to the 12ft scaffold pole I have that will be on the back of the house using t&k brackets do I need to earth it plus how do I swr
It as ladders dont reach
Thanks gentle giant
Tue Mar 20, 2012 6:28 pm
assemble the entire antenna and mounting pole and t&k brackets while it is still on the ground and lean it against a fence then connect it up and adjust the length of the antenna for lowest SWR reading between channel 1 and 40 UK , then when u have fixed your t&k brackets to the house attatch the pole with it slid down low then attatch antenna and coax then slide the pole up to hight and tighten . Earth wire is not essential but could be done at the CB end of coax with an adaptor if you feel you need lightening protection.
gentle giant
Tue Mar 20, 2012 10:48 pm
Thanks for the reply dragon fly
will be up and running soon hopefully
Gentle giant
