indoor cb aerial
gravecad
Wed Nov 21, 2012 5:16 pm
HI<
What is the best indoor cb aerial to fit a Cobra 19 DX IV EU?
Thu Nov 22, 2012 12:06 am
DV27 sat on a big fridge usually works well .
Thu Nov 22, 2012 6:19 am
or mount it in the attic on a ground plane
Fri Jan 18, 2013 5:31 pm
personally i would try the boomerang out easy to set up & can be mounted on to a balcony or on to a pole like the same way you would with a bigger antenna & easy enough to fit in to a loft as it comes with a u-bolt http://www.thunderpole.co.uk/base-cb-an ... erang.html
& i agree the DV27 is a good antenna but will need a big enough tin to mount it on to help the SWR also the tip has a section where you are also able to SWR the DV27 in what ever you pick i hope it all works out for you buddy :D
Sun Jan 20, 2013 9:22 pm
Inverted V Dipole set at 90% is omidirectional
http://www.k7mem.com/Electronic_Noteboo ... d_vee.html
anraj761
Mon Nov 04, 2013 6:40 pm
I agree that the DV27 is a good antenna, yet it need a big enough tin to mount right.
Tue Nov 05, 2013 9:34 am
you can always add to the tin if its not big enough by adding wire leads
