Install Antrone 99
BrokenSticks
Fri Sep 06, 2013 7:22 pm
Hi all,
I am planing on putting an Antrone 99 on the side of the house. If anyone has info and links to the sort of fittings I will need to do this so its safe and very secure, that would be a great help :) also any tips if you have them.
Thx
Fri Sep 06, 2013 10:28 pm
very good antenna works very well. and they dont brake in bad winds *King*
Sat Sep 07, 2013 10:14 am
T&K brackets about 3 feet apart with aq 6ft pole above the roof and you should be fine
BrokenSticks
Sat Sep 07, 2013 3:14 pm
as in the pole should be 6ft total? or 6ft above the roof?
thx
Thu Oct 31, 2013 8:16 pm
stampman wrote:T&K brackets about 3 feet apart with aq 6ft pole above the roof and you should be fine
above the roof mate 8)
matchbox
Thu Jul 21, 2016 1:24 pm
BrokenSticks wrote:Hi all,
Thx
Thunderpole sell em
