Burner
tobyw7
Thu Jan 24, 2008 6:28 pm
Any recommendations?
Have been looking at the RM Model KL200, 80 or 100 W (£45) depending on what you read, or KL400 which is 200W (£115) but also quite a bit more expensive.
Haven't found many others to buy online.
--Toby //
Fri Jan 25, 2008 8:36 am
either one depending on what you want to do dxing or local waste of time for local but needed for dxing
tobyw7
Fri Jan 25, 2008 4:13 pm
yeah i was looking to do longer distance work.. thx
Fri Jan 25, 2008 4:46 pm
if so the bigger the better
tobyw7
Sat Jan 26, 2008 4:22 pm
Cheers.. will take that into account..
tobyw7
Mon Jan 28, 2008 8:10 pm
Will i be able to use a burner portable.. in a car,
without the battery going dead on me
Is it a safe thing to do..
Tue Jan 29, 2008 8:37 am
run seperate battery in the boor with a caravan split charger connected up sand you will be ok
tobyw7
Thu Jan 31, 2008 7:37 am
Thanks for clarifying that.
Would the caravan split charger be the same as a split charge relay:
http://www.kampenwagen.co.uk/split%20charge%20relay.htm
-- Toby .
>> 26-Tango Mike-129 : http://www.tangomike.net
>> 26-Foxtrot Bravo-132 : http://www.foxtrotbravo.co.uk
Thu Jan 31, 2008 8:41 am
yes should think so
:D :D :D :D :D :D :D :D
tobyw7
Thu Jan 31, 2008 3:43 pm
Okay cheers.
Fri Feb 01, 2008 9:08 am
glad to help let us know how you get on
tobyw7
Sun Feb 03, 2008 4:46 pm
Yeah thank you. I think for the time being i'll have the rig set up for my car first. so i will only have to worry about the radio itself and the antenna
Then in a bit i'll organise an antenna of sorts at home etc
I'll let you all know how i get on anyway.
simonthewizard
Thu Mar 06, 2008 8:45 am
Run here the:
KL400
KL500
KL203
They are all working well and have never had any troubles with them, guess will do now.................... All seem to deliver the power well, and have small fans fitted on mine as helps with the heat, especially during the summer months
Apbuild
Sat Mar 22, 2008 5:50 pm
I have a KL 500.
Would a lack of power cause it not to work properly, ie, do I need to upgrade to a 40 amp power supply?
If I transmit from my office using no amp power, the signal is, of course clear as a bell in my jeep, some 100 yards away. As soon as the amp is turned on in the office, the transmission is lost altogether and all I get is a load of hiss.
Also, when the amp is on you can only TX for about three seconds before the rig restarts.
Any advice greatly accepted as usual.
Cheers,
Rob.
You got Eclipse coming at you!!!!!
I'd rather be mud pluggin, fishin', or shootin! (Or on my CB Radio)!
Sun Mar 23, 2008 6:48 am
you definatly need a power supply big enough to drive the burner and cb if it is working then you might be too close with the car
