Best way to set up.
barbelmadal
Mon Jan 29, 2007 8:54 pm
Could anyone tell me the best way to install inline these components, at the mo am having problems.
I have got a this set up, nato 2000 going to a Zetagi C57 freq meter to a zetagi HP1000 transmatch to a Zetagi B300P linear to an antron 99 30 ft up.
SWR keeps piddling around and set up does not like to work with freq meter in line.
Any help would be appreciated.
Tue Jan 30, 2007 9:33 am
get rid of transmatch and swr the antenna then replace swr with burner problem solved
barbelmadal
Tue Jan 30, 2007 6:53 pm
The transmatch is only inline as an swr & watt meter, I do not use the matcher part of it.
Tue Jan 30, 2007 8:05 pm
if you leve it in line you lose power thrue it and it will drive you crazy with the swr just set the swr across all the bands your using and remove the meter
and good luck
:D :D :D :D :D
