bit thick here
A place for homebase users to chat when they're not on the air
randombod
CB Handle: randombod
Sun Jan 31, 2010 5:06 pm
I am new to the home base cb scene i was wondering what i need to get one up i have an old union cb a power supply from thunderpole i think will power it and a small mag mount i take it the antenna needs upgrading but what about the rest. The one in the car is now champion (cheers andy and crew) but i have always wanted a home base one but her in doors has my bank card...... so whats missing from the list / needed?
cheers guys
Mon Feb 01, 2010 8:10 am
just a home base antenna it would seem
randombod
Mon Feb 01, 2010 2:09 pm
shame i cant use a big mag mount clagged on the o/s as a temp measure
Tue Feb 02, 2010 7:43 am
mag mount on a fridge or cooker or any large metal object will do if swr is reasonable suppliers do a ground plane system you could fit in loft
randombod
Tue Feb 02, 2010 1:15 pm
excelent ill have to have a bash at that some time see what the out come is
Tue Feb 02, 2010 1:49 pm
no problem good luck
Tue Jun 11, 2013 11:01 pm
triple loaded thunderstick in the attic on a biscuit tin would work well i would guess :lol:
AppleTree
CB Handle: Ben
Tue Jan 07, 2014 10:42 am
I had a mag mount with a spring whip in my loft and it didn't work... The SWR was always sky high and wouldn't go down...
It worked better stuck on my radiator on the ground floor!
One Life, Live It!
Buzzin' Around Channel 11 Usually.
Tue Jan 07, 2014 12:35 pm
A 18ft GP works well in the loft though a bit directional . 8ft 3in either side Wire dipole works quite good in the loft .
AppleTree
CB Handle: Ben
Tue Jan 07, 2014 2:40 pm
Might as well just stick an antenna outside lol
One Life, Live It!
