that landrover question again
philbert
Mon Jun 30, 2008 1:17 pm
hi all.
having problems fitting a twig to my canvas roofed landrover.
it seems anywhere i fit it i cannot get the swr down its normally of the scale!
is this because its alloy bodied or because im not getting a good enough earth on the mount?
its a sirio hypower twig with so239 thru body mount.
help please
Mon Jun 30, 2008 3:51 pm
TEST THE CABLE FIRST NO SHORTS AND CONNECTION FROM 1 END TO THE OTHER
:D :D :D :D :D :D :D :D
philbert
Mon Jun 30, 2008 8:22 pm
yep checked the cable no shorts and connection from end to end
Tue Jul 01, 2008 7:44 am
check continuity between antenna and pl259 at rig end if its a ml145 then you should have a short on the cable
philbert
Tue Jul 01, 2008 5:31 pm
have just checked with a ml145.
i get continuity between the whip and the centre and the outer of the pl plug.
Wed Jul 02, 2008 7:53 am
check the patch lead and make sure the swr meter is in the correct way i haveconnected them up wrong at times ::-()
philbert
Wed Jul 02, 2008 2:12 pm
the patch lead is fine no shorts.
the swr meter is working fine if i connect up a mag mount i can swr it in no probs.
Wed Jul 02, 2008 3:00 pm
check mthe mount although if you are getting a reading then that should be ok if the swr is higher on 40 then chop a bit off the whip if its higher on 1 then its an earth problem
philbert
Wed Jul 02, 2008 5:02 pm
Thanks will go and try re mounting the twig and start again .
cheers
Thu Jul 03, 2008 8:08 am
this is what made britan great we never give up =D> =D> =D> =D> =D> =D> =D> =D>
dannym2710
Mon Jul 07, 2008 6:42 pm
i was getting a bad swr on my hardtop 90, so ran an earthwire to the rear xmember, and its fine now.just used a piece of amp wiring from a car soundsystem (the red stuff)
philbert
Mon Jul 07, 2008 7:47 pm
tried that before with a jump lead to the chassis but it made no difference!
harryhedgehog
Fri Jul 18, 2008 9:27 pm
Was expecting problems last week when I fitted my first cb & aerial as I was away for the weekend and was desparate to try it out.
Get yourself a military roll bar under the tilt and mount to that, mine perfect so far (fingers, legs everything crossed) :D
philbert
Fri Jul 18, 2008 9:48 pm
got it sorted just drilled a hole in the front bumper and fitted it there!
works a treat wont do much for distance though !
but then again its only for use when im out with mates so distance isnt needed :D
Sat Jul 19, 2008 9:06 am
good another happy customer
