Anybody Used One Of These ?
TheJester
CB Handle: The Jester
Mon Jul 13, 2009 6:35 am
Anybody out there used one of these and if so, how have you connected your antenna, cabling etc...
Im thinking of getting one and running cable into car via rubber grommet that currently takes windscreen wiper cable....
Regards,
The Jester
HANDLE : The Jester
Mon Jul 13, 2009 4:52 pm
providing the earth is good then you should be ok
:D :D :D *King* *King* *King*
TheJester
Mon Jul 13, 2009 7:41 pm
Would I get a proper earth from just filing away the paint on the bracket where it attatches to the bolts ? Or would I need to run an earth to the car body etc. Also I am looking to fit a wilson 1000 to the bracket what connections would you suggest ?
HANDLE : The Jester
Offplanet
Tue Jul 14, 2009 11:46 pm
It's Ok for protecting the antenna in off-road situations and looks good, but the mount finishes half-way up the back window, so not too good for range and maybe the SWR will be a problem too.
If you can mount an antenna on the roof then do that, as it's the optimum location.
Gary
Thu Jul 23, 2009 4:19 pm
swr should be ok as it is along side glass for the base coil
killer cam
CB Handle: killer cam
Thu Jul 23, 2009 5:38 pm
:D :D
Mon Jul 27, 2009 1:35 pm
SEEN THESE :D
killer cam
Mon Jul 27, 2009 5:43 pm
same here porky
Thu Jul 30, 2009 8:22 pm
yep seen them are they any good ??
