Fitting the CB to Discovery 1
CaptainCaveman
CB Handle: CaptainCaveman
Sat May 04, 2013 11:19 am
I have just taken delivery of the Maxon CM10 CB and as i dont like playing with auto electrics! What is the best way to get it fitted.
Andy
Sat May 04, 2013 1:48 pm
use cigarette lighter plug or wire straight to battery
Thu May 16, 2013 10:41 pm
hi CaptainCaveman
stampman means one of these at the following link http://www.thunderpole.co.uk/products/f ... -plug.html also if you have a mag mount with your antenna all you will need is a patch lead & a SWR meter to check if your SWR on your antenna is below 1.5 mate
if you give Andy a ring he will be happy to help you out :wink:
