Discovery 2 Antenna Position
mavrick69
Tue Oct 23, 2018 7:39 pm
Greetings All,
First time on here so go easy...lol
I have a D2 that im sorting out to go gout and about in. Im looking at getting the following as a set up.
Albrecht AE-6110 Multi - Nice and slim and should just about fit above the sun visor so out of sight.
I was going to marry that to a Orbitor HD with a HD mount.
The question is would it be better to mount it on the front of the roof rack behind the raised bar as below with a HD mount? Its going to take a pounding from low trees and the like so would rather try and get it right first time.
IMG_1019 3.jpg (133.15 KiB) Viewed 718 times
or on the high rear quarter panel here ?
Many thanks for your thoughts in advance
Mike
Sat Oct 27, 2018 10:03 am
hi would mount on the roof rack ans remember that the orbiter does not work well up against metal as it would put the swr really high so keep it in the clear
mavrick69
Mon Oct 29, 2018 8:47 am
No Worries,
was going to mount it on a metal plate and fix it to the mesh about a foot back from the front
Mike
AppleTree
CB Handle: Ben
Fri Nov 30, 2018 7:04 pm
I also have a TD5, you want to mount the arial in the middle of the roof really, that way it will radiate equally in all directions. If you mount it to the front it will send signals backwards and so on...
Keep it away from any other metal as it will effect how it works. It looks like you have the prefect option there to stick it smack bang in the middle! I don't have anything on my roof so I used a Mag Mount. On my old Discovery 1 I used a gutter mount and out it on the rear right corner, which made it directional towards the front left. But, it worked.
One Life, Live It!
Buzzin' Around Channel 11 Usually.
AppleTree
CB Handle: Ben
Fri Nov 30, 2018 7:05 pm
Can you post a photo of how and where you put the radio please?
I'm thinking of relocating mine but I'm out of ideas lol.
One Life, Live It!
