merc axor
bub
Wed Nov 14, 2007 10:47 pm
I plan to install a cb and antenna in my merc axor. am new to this so advice on which antenna and cb and mount including routing the coax would be great.
Thu Nov 15, 2007 6:43 am
dont lnow the waggon as sutch but you probably would be better calling in to a cb dealer and getting him to give it the once over actrosses are fairly easy to do so if yours is built the same way then should be a doddale
Wed Apr 23, 2008 10:33 am
stampman here is a picture of a merc axor,
i would think about a mirror mount with a orbitor antena then you will be able to fit the coax through the door,
i would pick a basic cb radio like this one in this link,
http://www.thunderpole.co.uk/team_mc8.htm
i do have to say it does look a good radio might buy one of those my self one day anyway bub hope this information has helped you out buddy take care and happy cbing and happy trucking.
Thu Apr 24, 2008 8:44 am
yup try the mirror mount but make sure you check the swr and see what it says the orbiter should work but make sure its as far away as you can get it from the bodyas that will give you reflection and a high swr but good luck let us know how you go on
