president lincoln antenna
slimfb
Mon Aug 27, 2012 5:29 pm
hi all
i have a lincoln that i want to use at home.......prob too good for the truck
i am about a meter above sea level...on flat land....on an estate....in a house with a loft
without going to extremes but bearing in mind i have a lincoln & would like to make good use of it, what initial antenna setup would you guys advise..........i am a newbie :?
thanks in advance
slimfb
Mon Aug 27, 2012 8:22 pm
just to try out the lincoln
i am upstairs in a small room with radiator, ( 1 meter above sea level near peterborough) could i 'stick' a mag springer on & use the rad as a ground plain, then use the lincoln ........... would that work ok ? i need a springer for my truck anyway
cheers guys
Mon Aug 27, 2012 11:23 pm
yes should be fine for a little while, but you need is a outdoor antenna realy :D *King*
slimfb
Tue Aug 28, 2012 7:06 pm
ok thanks, i'll start my homework
Tue Aug 28, 2012 7:56 pm
the springer antennas are not much kop for in door use
slimfb
Tue Aug 28, 2012 9:13 pm
think i'm going to need planning permission to stick one on the house :( & got the neighbors from hell #-o
slimfb
Tue Aug 28, 2012 9:47 pm
is there a maximum length for the coax ?
Thu Aug 30, 2012 8:33 am
no maximum length you could try a wilson 1000 antenna not cheap but would do aa Stirling job
slimfb
Fri Aug 31, 2012 9:28 pm
i might just bite the bullet & put a sirio gm on the side of the house.......at the roof apex, so high up.......hope nobody complains [-o<
Sat Sep 01, 2012 8:53 am
will be a seven day wonder then no one will bother
Sun Sep 02, 2012 1:07 pm
slimfb wrote:i might just bite the bullet & put a sirio gm on the side of the house.......at the roof apex, so high up.......hope nobody complains [-o<
good luck *King*
