User issue midland 98 plus
Bigman1207
Sun Sep 04, 2016 9:05 am
I don't think my rig is broken more a lack of user manual so I will describe the issue . . . .
When I switch radio on I get three beeps volume up full squelch turned to minimum I get no noise
It also if I keep squelch button pressed makes another beep esl I have no idea what this is or does
Sometimes say fifty percent of the time I get noise ap per normal when the squelch is turned down
Aerial and mic connection checked where the screw in and seem okay
So my operating fault or rig fault?
Oh it's wired via cig lighter in a van
Bm
Bigman1207
Sun Sep 04, 2016 12:46 pm
It's got esp not what I said above! Sorry
Mon Sep 05, 2016 12:35 am
Sounds like the recieve wire has broken tn the mic plug .
25042013297 (2).jpg (589.13 KiB) Viewed 3346 times
Bigman1207
Mon Sep 05, 2016 9:10 am
Brilliant thank you for the reply will have a look later today many thanks
Bigman1207
Mon Sep 05, 2016 10:12 am
All wires in mic plug are connecter amd also in the mic itself wires are different colours though to the diagram
Cheers bm
Bigman1207
Mon Sep 05, 2016 12:04 pm
All put back together same as previously not had noise for quite some time now on.matter how many times I switch on or off
Bigman1207
Mon Sep 05, 2016 12:05 pm
Is there a way to check by bridging pins on the cb with Mike removed?
Bigman1207
Mon Sep 05, 2016 12:24 pm
Google search
Okay bridged pins c and r on full volume got a very very slight buzz only just audible
Any ideas?
Mon Sep 05, 2016 1:37 pm
Could be a faulty squelch control, or could be adjusted incorrectly inside the unit.
