Could I use a mobile antenna for a home base antenna?
Johnny Mac
Sat Mar 25, 2017 3:15 pm
I've got a Sirio 5000 PL with a mag mount and I was wondering if I could use this at home or would I have to make some alterations to it.
Also with power supplies, can I run a CB and 100w amp from the same supply?
Thanks John
Mon Mar 27, 2017 9:42 am
For the Sirio 5000 to work it would need a groundplane, so you would need to find some metalwork to mount it on.
You could, but it would have to be at least 12 amp continuous rated.
Johnny Mac
Tue Mar 28, 2017 7:00 am
Great thanks for the advice :)
blueovalcraig
CB Handle: Blueoval
Location: Rothesay, Isle of Bute, Scotland, United Kingdom
Wed Aug 28, 2019 4:09 pm
Am I right in thinking that if I plonk my magmount Sirio ML145 onto a metal biscuit tin in my shed then it should work ?
Call Sign: 108CT167 Handle: Blueoval
2003 Land Rover Discovery ES TD5
Maxon CM10
1999 Land Rover Discovery ES TD5
Thunderpole T2000
www.scotgrc.co.uk
www.thed2boysclub.co.uk
1993 Rover Mini Cooper (ongoing rebuild)
Kernow Beta4100
Enterprise
CB Handle: Stingray
Thu Aug 29, 2019 9:30 pm
Yes, it will work, but probably won't get out very far compared to a properly mounted homebase antenae. Check the SWR before using it.
blueovalcraig
CB Handle: Blueoval
Thu Aug 29, 2019 10:03 pm
Cheers Enterprise.
Did that and SWR was above 3 tried adjusting but no joy so looks like I’ll be ordering a Homebase antenna soon
Maxon CM10
Thunderpole T2000
www.scotgrc.co.uk
Kernow Beta4100
Enterprise
CB Handle: Stingray
Fri Aug 30, 2019 1:30 pm
Try a basic 1/2 wave silver rod, available for around £30. Easy to SWR in apparently. Get some decent RG58 coax and PL259 plugs or buy a ready made up 10 or 20 metre coax length.
AppleTree
CB Handle: Prospector
Sat Aug 31, 2019 3:03 pm
Silver rods are cheap, but Antennas like an iMax2000 or A99 ahve rings to tune them, much easier. But, they're more expensive.
If you're getting coax too, RG213U is cheap and very good but remember to buy the right PL259's to go with it.
Or 145.500 FM 8-)
blueovalcraig
CB Handle: Blueoval
Sun Sep 01, 2019 5:47 pm
Thanks my friends.
Not wanting to spend a lot initially as I need to see if I ‘get into it’ or not.
Will let you know how I get on
Maxon CM10
Thunderpole T2000
www.scotgrc.co.uk
Kernow Beta4100
AppleTree
Wed Sep 04, 2019 8:35 am
Next Tim I hear a crazy Scotsman I know it's you
Or 145.500 FM 8-)
blueovalcraig
CB Handle: Blueoval
Wed Sep 04, 2019 5:45 pm
Aye ken that’ll be me
Maxon CM10
Thunderpole T2000
www.scotgrc.co.uk
Kernow Beta4100
