scanner aerial advice!
bigwing
Tue Jul 14, 2009 3:09 pm
Hi again I have a realistic pro-2006 scanner but i dont have a dedicated aerial, what i have done however is tap into the TV aerial by way of DIY genius but will i have gaps in what i can recieve etc or am i good to roam the waves?
thanks guys! :?
disgwylfa
CB Handle: 186-TM-555
Thu Jul 16, 2009 5:10 pm
You're "good to roam the waves" . . . . But... You could be "gooder" :wink:
If you use a bit of wet wool as an antenna you'll still get full coverage, but you'll pick-up a heck of lot less than if you use a "proper" aerial.
The TV aerial is a lot better than a bit of wet wool, and you won't have any "gaps" but it is not the best solution. For a start a TV aerial is directional (it's like a mini Yagi beam) so it receives best from the direction in which it's pointing, and poorly elsewhere and second, it was designed for specific TV frequencies.
Get yourself a scanner "Discone" antenna and that'll give you the best general coverage possible.
. . . . Cherokee
