Sirio Balcony, anygood ?
S109
Sun Aug 23, 2009 11:23 pm
Just browsing the Thunderpole shop at the homebase antenna's and see the Sirio Balcony. Are the anygood ? I wouldn't get away with an 18ft+ antenna ouside but rekon I could mount the 27W outside just under the sofet, would it work well ? I think the 27A would be too long :roll: .
Thanks.
Mon Aug 24, 2009 8:09 am
sirio balcony see to give short range you could try the dv27 with home built ground plane fixed to the soft use it pointing down and run the ground along the sofit
S109
Mon Aug 24, 2009 8:12 am
Stampman, could you explain it in a bit more detail please :oops:
Thanks.
padster
CB Handle: night owl
Mon Aug 24, 2009 6:53 pm
S109 wrote:Hi,
Thanks.
i bought the dv27 from thunderpole got it last it on friday and set it up its great :D :D :D :D :D :D :D
Mon Aug 24, 2009 8:56 pm
:D :D
Tue Aug 25, 2009 7:54 am
if you mount the dv27 on a bracket useing a dv mount hen run 9ft of cable from the base of the bracket along the sofit you should be able tol swr the antenna ok
and also get the dv as vertical as you can
Tue Aug 25, 2009 5:26 pm
:D :D :D :D
S109
Tue Aug 25, 2009 6:42 pm
Stampman how does running the cable along the sofit help the swr :oops:
FISH
Tue Aug 25, 2009 6:50 pm
its used as a gp bud.
26 TANGO MIKE 501
S109
Tue Aug 25, 2009 8:38 pm
Thankyou. :D
Tue Aug 25, 2009 8:48 pm
gp
Wed Aug 26, 2009 7:50 am
gp = ground plane not gross product
FISH
Wed Aug 26, 2009 9:22 am
Like it m8. =D> =D> =D>
26 TANGO MIKE 501
Wed Aug 26, 2009 8:01 pm
:lol:
