help
padster
CB Handle: night owl
Sun Jul 11, 2010 8:05 pm
well my rig works i got aerial in loft but not getting out far does it need to be earthed and if so how
Mon Jul 12, 2010 10:04 am
depends on the swr if that is out then you need a ground plane if its ok then just could be location
padster
Mon Jul 12, 2010 2:45 pm
stampman wrote:depends on the swr if that is out then you need a ground plane if its ok then just could be location
got the swr down to 1.5 on chaneel one and 1.4 on channel forty
26-TM-037
Mon Jul 12, 2010 3:29 pm
What antenna are you using in the loft?...and does it have or require a groundplane?
padster
Mon Jul 12, 2010 3:52 pm
26-TM-037 wrote:What antenna are you using in the loft?...and does it have or require a groundplane?
dv 27 on a large tin wich is sat on 8 foot of tin foil
