balconey antenna
gravecad
Wed Apr 20, 2011 3:28 pm
hi
could anybody recommend a cb antenna for a bolconey on a block of flats. i am one floor up and have been using a indoor aerial for about a year.
thanks.
joe jeep
CB Handle: Joe-Jeep
Wed Apr 20, 2011 4:24 pm
9' Tank Whip - http://www.thunderpole.co.uk/tank-whip.html (make sure your groundplane is sufficient though)
or any of the homebase cb aerials, although I would exclude the excalibur if you were already using an internal antenna, one of the homebase aerials should suit your setup. http://www.thunderpole.co.uk/cbhomebaseantenna.htm
Handle:Joe-Jeep
ellitanthalas
Wed Apr 27, 2011 3:35 pm
Oddly enough, Thunderpole do a specific balcony antenna - called the Boomerang!!
I have one myself. Is very good!
It's not about luck, it's about skill.
Wed Apr 27, 2011 4:32 pm
I remember a block of flats in Leeds that had a Antron 99 on 6ft of pole and it was just leaned against the balcony and tied.
