Wire homebase antenna
Home Guard
Sun Jan 22, 2012 10:35 am
I've heard of people on HAM bands using wire antennas stretched across there fence or roof, I was just wondering why it isnt so popular in CB?
And how would I go about contructing one of these?
Thankyou. :D
Mon Jan 23, 2012 8:13 am
cb is designed to work on a vertical antenna and a wire is horizontal so would not work as effectively
Adriano9966
Mon Jan 23, 2012 9:54 am
:D wire attic dipoles can work well for cb ...I have one but it would work better for cb as an inverted V as this will give near vertical omnidirectional signal path whereas horizontaly polarised will be bidirectional :wink:
:) Its important to include a choke at the feedpoint to prevent the coax(if you are using coax instead of twin line) from becoming a part of the antenna.
