hi all.
having problems fitting a twig to my canvas roofed landrover.
it seems anywhere i fit it i cannot get the swr down its normally of the scale!
is this because its alloy bodied or because im not getting a good enough earth on the mount?
its a sirio hypower twig with so239 thru body mount.
help please
that landrover question again
check mthe mount although if you are getting a reading then that should be ok if the swr is higher on 40 then chop a bit off the whip if its higher on 1 then its an earth problem
dannym2710
i was getting a bad swr on my hardtop 90, so ran an earthwire to the rear xmember, and its fine now.just used a piece of amp wiring from a car soundsystem (the red stuff)
harryhedgehog
Was expecting problems last week when I fitted my first cb & aerial as I was away for the weekend and was desparate to try it out.
Get yourself a military roll bar under the tilt and mount to that, mine perfect so far (fingers, legs everything crossed)
