Why does my three week old midland 98+ sometimes 'start up' perfectly and sometimes just sit there with no display?
Could this be damp? or a less than perfect powerfeed?
For example, I tried it in my old mini (engine running) - no display.
And then I tried it in my peugeot 307, engine off - perfect.
Or is this a red herring and does it go back for replacement??
Cheers.
Midland 98+ - No startup beeps
daemonchild
Yeah - that's what I thought.
Tried it again this morning in the 307 - perfect even thought it was snowing outside...
Hmm. Second battery in the mini?! Cheers.
- jdo330
- Official CB Nut
My 98+ does the same thing and thats in the same vehicle too.
Also, sometimes when I switch it off (using the volume knob on the rig - its wired direct from the battery) the illumination goes but you can still see the channel digits (ie, 19).
Its annoying but ive learned to live with just disconnecting and re-connecting it.
ATB, Jon.
ATB, Jon.
daemonchild
I've done a couple more tests.
Even in the Pug with engine running, I get the same when there is another draw on the battery (lights, A/C etc.)
I noticed that when I have a 4 way adapter on the cigarette lighter, no joy. Without, perfect.
Hmmmmmmm.
I have another rig for the other car (still in it's box).
Will try this one.
Hmmmmmmm.
Will try this one.
daemonchild
I got the second rig out of it's box and tested it. It's perfect.
So I *think* the first one may be faulty.
I'm going to put it somewhere warm for a few days to see if there is damp inside, but if it's not fixed, I'm going to try and get a swap done.
Cheers for your help guys.
stampman wrote:damp should not affect it unless you have been useing it when scuba diveing if so then you have a problem other wise damp does not affect them
I disagree, I've left rigs in the car overnight for long periods during the winter and they do suffer on the modulation. A day or so in the airing cupboard helps cure it.
mine stays in the car and has done from about 1975 and never had a problem but if you use a soft top then it might be a problem damp could effect a very old mic insert but with the new condeser mics cant see it being a problem and another thing that could effect the mod is low voltage from a standing battery or bad connection on the power supply ie scotch locks
extremedave
when did CB become legal again?stampman wrote:mine stays in the car and has done from about 1975
