cb Fault ?????????????????????????????????
andyd99
CB Handle: andyd99
Right guys managed to get myself a rig sorted--------- in fact the wifes dad is a trucker, and hes give me a set up out of his old truck.
The downside---- ----- it worked ok for the first few days until last night. I thought there was a bad earth off the radio where I originally wired it upto, so i wired to a cigarette lighter socket, switched on it worked great, seemed to be gettin an even better signal, then all of a sudden, the display started to fade, made a few beeping noises and went off, now it wont come back on again.
I also found that i could hear ok but noone was responding to my test calls.
Its a Kernow 3100 beta, which im told is the same as a midland 38, but the old stock line?
Is this a common problem with cb's as this is my first one, and can they be repaired at all? Does anyone know anywhere around the Stoke/Staffordshire area that does cb radio repairs at all.?
yes they can be repaired try the fuse first if thats ok make sure you are getting voltage to the cb if its still dead then andy on here will repair it for you in northampton
andyd99
CB Handle: andyd99
Many thanks for the reply, this may seem like a daft question, but where abouts is the fuse located, is there one in the actual rig itself? it comes on for a short time, then it just goes off as if its reached a certain temperature, and doesnt want to play anymore. :? :?
fuse ok the no fuse inside set sound like a thermal fault can be sorted ok
Daedalus
Just a thought but If the rig sometimes lights up then goes off maybe there is a problem with the power lead like a break in the wire or power cable. This could be true Especially if the rig has been moved in and out of a vehicle frequently.
Please don't take offense, but perhaps you wired it up badly and it has a poor power connection. Before you start to open her up I would check all the wires and connections, Make sure there is nothing wrong, that can short out if moved or broken.
HARRIER - CBX ---quality CB built on the famous Cyberrnet 134AOX board.
'Breaker One-Nine, what's your 20? I Hammer'd Down on the A3
I eyeballed a Kojak with a Kodak so I pulled in behind a Suicide Jockey.'
try tapping the power leads it sounds dum but my radio had its fuse tookin out for 12 months and i put one in works fine but if you knock them it wont come on so u tap them and they work :D
and dont use scotch locks they are the kiss of death to cb radios
