I have a SS3900 That I’m supposed to be selling for a friend [He wants at least £100.00 for it which includes the freq Counter and Cobra HG M75 Power Mic]
Before I put it up for sale I wanted to test the Rig as he no longer has any setup.
The radio seems to have a weird problem. When connected to my antenna every few seconds the radios signal meter will hit 9 pound make a buzzing noise and return to ‘0’. It makes no difference what band or channel its on.
I’ll be honest that I’m not 100% sure how to work this rig properly I've only played with it for a few hours, but I’ve uploaded a 15 second video clip to You Tube so you can see what I mean.
http://www.youtube.com/watch?v=bQ_Xup0F ... annel_page
The radio was bought from new, used for 4 months and then boxed away until now. I know it works as 1. I’ve seen/ heard it receive/ working on USB and Uk40 dispite this Buzz, and 2. I was on the receiving end of the TX for those 4 months when my friend was using it.
I’ve powered down almost EVERYTHING in the house to see if it was local interference but It still dose it and its not the PSU as I've also tried a battery.
I’m beginning to think that there’s nothing wrong with the radio but rather it’s actually my main antenna [Which hasn’t been used or maintained for about 6 months] as when there’s no antenna attached or I use a mag mount this buzzing doesn’t happen.
One thing I perhaps should mention is that I’m using the same antenna that he used the SS3900 on a Thunderpole 5/8 wave Silver rod–This was bought with the radio and I had it off him when he packed up ‘CB’ radio to replace my ageing 1992 ½ Wave Silver Rod!
I would hate to tell him it's now a scrapper considering its 'as new' and all the money he invested in it, but this Buzz is beyond my knowledge. Any help or advice would be appreciated.
Superstar 3900 Gives Strange Noise!
- Firetrap
- CB Handle: FireTrap 26CT100
I bought a rig that did the same, turned out to be TX'ing automatically for about 2 seconds every 30 seconds!
I opened the rig up and blasted it with compressed air then tried again and then it was fine!
It could be a build up of dust that may be shorting something, after all dust can conduct a current!
Try the compressed air, gotta be worth a go.
Good luck!
Good luck!
