How well would a mobile antenna work as a homebase antenna
My son has just bought a cb, well i got him one just to give it a go, but he doesn't want to spend much on an aerial yet, so i thought could he expect to work any good of a mobile one? and how would it need fitting, he is setting it up at his nans house about three miles from me, so could he at least do the three miles?
if you get something like a sirio dv27 and set it up as high as you can 3 miles would be easy not an expensive antenna and good quality get the swr right and you are sorted use a ground plane made out off wire about 8ft 6ins long
- andy@thunderpole.co.uk
- Site Admin
Yes as stampman says 3 miles shouldnt be a problem with a decent antenna mounted high enough.
If you are using a mobile antenna you will a 'ground-plane' though. As normally they would use the metal vehicle underneath.
You can acheive this with a magmount mounted on something metal, i.e. old radiator, old filing cabinet, or as people used to use... a biscuit tin!!
DV27 - £10.99 - http://www.thunderpole.co.uk/sirio_dv27.htm
i,ve just came back on the scene and the chaps at thunderpole sorted me a dv-27 and a ground plane kit,
its in the loft, swr,d it to just below 1.5 and it gets out about between 8 - 10 mile pushing 5 - 6 and modulation 4, which i think is not bad for a mobile antenna !
breaker 19
- Official CB Nut
my brother used to keep a mobile antenna on top of an 8 foot scaffold pool and managed to get a good 12-13 miles out
i,m thinking of comeing down and buying a antron 99, are they good and if i do put one up its got to go down the side of my house onto a chimney stack, running down the stack is a sewer breather pipe and its got to go along side of this, would the pipe effect the antenna as this is the only option i have to put it on the house, the stack is a good 15 -18m tall and the pipe runs to that length as well or could it be clamped to this, cheers
