or if motor is mounted in plastic or rubber bushes try earthing motor to chassie
Man alive!!!!!
pro.farmer
I get interference from the compressor for my air seat and also from the rear wiper motor. turning up the squelch a degree or two seems to stop it but then it can be difficult to pick up weak transmissions.
It is the only way. A fellow breaker in our neck of the wood spent a week supressing everything on the John Deere 7710 he drove and tin-foiled all the inside of the cab roof. He did have the best setup for miles around tho.
Forgot to say, welcome pro.farmer. Glad to see theres at least 2 of us who appriciate the finer things in life. (blue bonnets!) 8) Another thing ive just noticed aswell raiderz, your location is Spennymoor. called in there before xmas to see a mate working in the fields and some numpty was playing happy hardcore dance music on channel 19! Whats all that about?
pro.farmer
you cant beat a blue bonnet! what models are you working with. i prefer to stick with older ford based ones, currently running 7810 7740 and 8240. had ts135a on demo but wasn't heavy enough at front to hoist combi drill on hillside with full hopper.Spike wrote:Forgot to say, welcome pro.farmer. Glad to see theres at least 2 of us who appriciate the finer things in life. (blue bonnets!) 8)
pro.farmer
nice fleet! SL-DP's SLEs??? Do you ever get bother with pinion shaft on front axle?Land-Ahoy wrote:
Were running two 7840's,6640,8340
pro.farmer
We had the gearbox grind to a halt on our SL dual power, caused by 3 studs which held a bearing housing to the casting working loose and the balls rolled about damaging all but 4 gears. Over £5000 damage!! SLE has been no bother tho.
We run a 1998 New Holland 8560 for the main of the contracting and a 1995 7840 SLE special Turbo at home, with 9800hrs on. Best tractor we've ever had. The 8560 smashed its gearbag up last harvest wich wasn't cheap, but it is running at 174hp at the shaft. 8)
And we have a John Deere but i don't want to talk about it.
pro.farmer
Whats so bad bout the deere? Apart from the obvious, its not a ford!
Could have been the lad that works for me he fits the "numpty" description lol, you should try channel 40 during the afternoon, we normally get pensioners with massive burners blasting out geriatric dribble on how much a tin of beans is at Tescos, its really annoying these old timers are pumping out megawatts of blue-rinse chat every day!Spike wrote:raiderz, your location is Spennymoor. called in there before xmas to see a mate working in the fields and some numpty was playing happy hardcore dance music on channel 19! Whats all that about?![]()
